2014 Toyota Sienna
Mike if this is against the rules to post about this vehicle please delete. I have started doing all the maintenance on my parents vehicles and the Sienna has a bad pull to the left. What causes this? I have checked fronwheel bearing play but nothing. Stuck calipers? Thanks!
  • Replies 1
  • Views 999
  • Check alignment / bent suspension parts.    Also try cross rotating the front tires to check for a lateral pull. Could be a manufacture defect   Brakes sticking could be a possibil
Brakes sticking could be a possibility, but you could tell if they are hot to touch the wheel.
