P0069, P0107, P0243, P2149
My Mom ask me if i could check out her truck its a 2005 with an birddog fuel pump straight pipe. It use to have an edge but took it off because it started causing problems. I read Mopars Article on the P2149 code and was wondering if there was a wiring harness map for the truck. The other 3 codes i was wondering if they may be in conjunction with each other? Im thinking a bad MAP sensor but not for sure, let me know what you guys think.
  • Views 1.4k
No posts to show
