Valve seal replacement questions
Recently I've been getting after some much needed maintenance on my 24v.  So while I replace my tappet cover gasket and vacuum pump seals I'd like to throw in some valve springs, valve seals, head studs, and any other seals/components I can get to at the same time. I know the valve guides are known to wear on 24v's so I'll make sure to take a peek at those too. I just rolled over 200k.
So my questions are:
What seals should I use for the valve stems? I hear something about CR seals being used as an upgrade?
What other components/seals should I be replacing/inspecting at the same time?
  • Views 993
No posts to show
