Hello...I’m having a problem with my 2002 Dodge 2500 Cummins. I bought the truck in 2018 with an Industrial Injection VP44 Hot Rod pump and a tuner. I use the truck primary to haul my two Australian Shepherds back and forth to a local trail we like to utilize. About 4 weeks ago my wife took the dogs to the trail for a walk. When she went to start the truck, to return home, she said that she had to crank the engine over a long time until it finally started. I didn’t think much about it, but couple days later I was driving the truck and it started missing. I made it back home but by that time the truck was belching smoke and wouldn’t stay running. The truck set the infamous P1688 code. I contacted Industrial Injection and purchased a new/rebuilt 235 HP VP44. I installed the pump and drove the truck a couple miles with no problem. The second day I decided to venture a little further and take some garbage to the transfer station. On the way to the station, I had to stop at a redlight. With my foot off the accelerator and the brake applied, the engine shut off. I tried to restart it but without success. A tractor trailer behind me started blowing his horn. I got out of the truck and motioned him to go around. I jumped back in and hit the starter again and the engine fired up. I quickly drove across the highway and into a parking lot. I popped the hood and tried wiggling the connector at the injection pump and ecu while the engine was running to see if the engine would stop. It kept on running. I turned the truck around and drove home. On the way back I noticed the CEL was lit on the dash. I checked the code with my scanner and it was P1688. At the same time the PCM showed a code of P1693.
I called Industrial Injection to see what actually sets the P1688 code and they were not sure. They did tell me to make sure there was 12 volts at the pump. I checked with a meter and I measured 12.9 volts. I continued to investigate with my PICO scope. This is my question. When I measure the 12 volt timing square wave signal coming from the ECU to the pump, the signal drops to 0 volts when move the APPS off of idle i.e. cycle the idle validation switches. Is it normal to loose the idle timing signal when coming off of idle?....I performed the same test with a second ECU and it did the same thing. I have reset the all codes multiple times but they quickly return....help....
Thanks,
Kyle
