One page for every service on the 1998.5–2002 Dodge Ram 2500/3500 with the 5.9L 24-valve Cummins, shortest interval first. Use the severe column if you tow or haul often, idle a lot, drive short trips, or run in dust, cold or extreme heat. Items marked † are not in the factory schedule (see the footnote below the table).
Service
Miles (normal / severe)
Time (normal schedule)
Days (normal / severe)
Tire pressure †
Monthly, and before a tow
30 / 30
Tire rotation †
7,500 / 7,500
180 / 180
Engine oil and filter
7,500 / 3,750
6 months
180 / 90
Breather canister drain
Each oil change
6 months
180 / 90
Batteries and terminals †
Each oil change
Load test before winter (severe)
180 / 90
Chassis grease, steering, front end
Each oil change
180 / 90
Shocks and front end visual check †
Each oil change
180 / 90
Air filter
Inspect each oil change; stock: replace at indicator; BHAF: 50,000 †
BHAF: 3 years †
180 / 90; BHAF 1,095
Fuel filter and water drain
15,000 / 7,500
12 months
365 / 180
Lift pump pressure check †
Each fuel filter change
365 / 180
Water pump weep hole
15,000 / 15,000
12 months
365 / 365
Drive belts: inspect
22,500 / 22,500 (we use 20,000 †)
18 months
547 / 547
Brake linings: inspect
22,500 / 15,000
18 months
547 / 365
Fan hub and damper: inspect
30,000 / 30,000
24 months
730 / 730
Front wheel bearings (4x2)
30,000 / 30,000
24 months
730 / 730
47RE automatic: fluid, filter, bands
30,000 / 15,000
24 months
730 / 365
Brake fluid †
30,000 / 30,000
3 years; severe: each brake job
1,095 / 1,095
Power steering flush †
30,000 / 30,000
3 years
1,095 / 1,095
Transfer case fluid (4x4)
45,000 / 45,000
36 months
1,095 / 1,095
Shocks: test, replace when worn †
50,000 / 40,000
Yearly after first test
1,200 / 970, then 365
Axle fluid, front and rear
None listed (60,000 †) / 15,000
1,460 / 365
Manual transmission fluid †
60,000 / 60,000
1,460 / 1,460
Cooling system flush, conventional coolant
30,000 / 60,000
24 months
730 / 1,460
Cooling system flush, extended-life coolant †
75,000 / 75,000
5 years
1,825 / 1,825
Valve lash
150,000 / 135,000
150 months
4,500 / 3,285
† Not in the factory maintenance schedule. These are practical recommendations, not factory specs: tire pressure and rotation, battery and terminal care, the shock and suspension checks, the BHAF air filter interval, the lift pump pressure check, brake fluid, power steering fluid, manual transmission fluid, the 60,000-mile axle fluid suggestion, the 20,000-mile belt check, and the extended-life coolant interval. The factory time limits apply to the normal schedule only; the severe schedule is by miles.
Intervals come from the 2001 Dodge Ram factory service manual (Schedules A and B for the 24-valve Cummins) where the factory lists them. Days between: where an interval has a time limit, the days are that limit (6 months = 180, 12 months = 365, 24 months = 730, 3 years = 1,095, 5 years = 1,825). Where it is miles only, the days assume about 15,000 miles a year (7,500 mi = 180 days), so adjust them if you drive more or less. Enter the miles and days together as the Garage's repeat miles and repeat days; whichever comes first is due. Keep a log of date, mileage, service and parts for every item.
Maintenance Schedule: 1998.5–2002 Dodge Ram Cummins Diesel
By Titanium · Nov 24, 2026
Service
Tire pressure †
30 / 30
Tire rotation †
7,500 / 7,500
180 / 180
7,500 / 3,750
6 months
180 / 90
Each oil change
6 months
180 / 90
Each oil change
180 / 90
Each oil change
180 / 90
Each oil change
180 / 90
Air filter
BHAF: 3 years †
15,000 / 7,500
12 months
365 / 180
365 / 180
15,000 / 15,000
12 months
365 / 365
18 months
547 / 547
22,500 / 15,000
18 months
547 / 365
30,000 / 30,000
24 months
730 / 730
30,000 / 30,000
24 months
730 / 730
30,000 / 15,000
24 months
730 / 365
Brake fluid †
30,000 / 30,000
1,095 / 1,095
30,000 / 30,000
3 years
1,095 / 1,095
45,000 / 45,000
36 months
1,095 / 1,095
50,000 / 40,000
1,460 / 365
60,000 / 60,000
1,460 / 1,460
30,000 / 60,000
24 months
730 / 1,460
75,000 / 75,000
5 years
1,825 / 1,825
Valve lash
150,000 / 135,000
150 months
4,500 / 3,285
View full Cummins article
