- Replies 4
- Views 7.4k
mr.mindless 2 posts
cummins2k 1 post
jumpjg 1 post
Couple questions about a rear axle swap. I have a line on a 3.54 ratio complete assembly from a '98 2500. My truck ('99 3500 DRW) is fitted with a Dana 80.1) Does a '98 2500 diesel use a Dana 80?2) Are there differences between axles used in SRW and DRW applications?3) Are there any differences between the rear axles on a rear wheel only ABS truck & all wheel ABS truck (mine is the latter)?4) Are U joints the same between the two?5) Any challenges with attaching to the springs?I'm aware of the speedo cal issue. Anything else I'm not considering?Appreciate the help,Joe in St Louis
