Boost Fooler/ Elbow
Thinking about installing a Boost Fooler with Boost Elbow on my 1998.5 24V Cummins. If I do this before I install the RV275 injectors will I notice any increase in power or fuel mileage?It's cold and very wet here now. When the weather warms and dries up I will do the KDP, RV275 injectors and valve adjustment with the Boost Fooler. What's your advise?Thank you, Kerley
  • Replies 1
  • Views 1.8k
If your setup has the ability to fuel enough to create more boost than the factory wastegate setting allows, then yes, I think you would see an increase in power. The thing to remember is that you have to have the fuel to create the boost.Sent from my DROID X2 using Tapatalk
