Well this is my first post on here I've commented a few times on the sport headlight conversion but I was wondering if anybody thought it was possible to buy the headlights that were not sport but still had to bulbs and wire it up using the same harness style posted in the sport conversion thread these are the lights I was looking and and was thinkin about running the power wire from the oem harness to the high bean power low bear oem to low beam light and run the grounds through the same as in the picture but I still want to use the relays to take the heat off of the light switch I am fairly good at wiring and just wondering if anybody thinks this would work? Thanks for any input it's really appreciated
