bjytech - 97 2500 4x4 5spd.
The stats:
[*]1997 Dodge Ram 2500 SLT Ext. cab
[*]260K+ miles
[*]5.9L Cummins 12valve turbo diesel
[*]4x4
[*]NV4500 5 speed transmission
[*]KY clutch 3850# dual disk ceramic clutch
[*]1 3/8" cryogenically treated input shaft
[*]3.54 axle ratio with LSD in the rear
[*]265/75/R16 Cooper Discoverer A/T3 tires
[*]Custom cut fuel plate
[*]AFC full forward
[*]3k governor spring kit
[*]Timing set at 15.5 degrees
[*]Diamond eye 4" turbo back exhaust with 5" tip
[*]Glowshift 3-in-1 Boost, pyrometer, fuel pressure
[*]Boost elbow
[*]Amsoil EAAU4095 air filter with prefilter
[*]Mighty diesel head bolts
[*]Power at the wheels is sitting around 360HP and 800FT.LB. of torque right now.
[*]All maintenance, repairs and modifications done by myself.
Picture from after I brought the truck home back in fall 2012, will add more recent pictures later.
  • Views 2k
No posts to show
