bcayallday24vs
  1. i did get 2 brand new batteries. Also i got a new ultama alternator because i didnt have time to take old one off and get tested i had to work. I did however get a chance to take the old one to get tested and it passed. So i have 2 good alternators. Not to sure which route to go from here.
  2. Thank you for that info. Im actually a new owner to this vehicle and i think those may be old codes. because the first two it actually shows is 1693 and 1682. Then those others show up after. But i had the batteries on charge all day just went out and it cranked right up. Drove around for about 15 minutes, granted the check engine light was on the whole time. But after driving and everything seemed fine, I pulled into my garage and check gauges light came back on. Thats when i did the code checker with the key and found the 1693, 1682.
  3. So a little history on the truck its all stock no mods at all. Im driving the other day and my check gauges light came on, All the gauges looked fine except the voltage gauge. So the batteries have seen better days i got new ones. Installed those and the truck was fine until about 15 minutes driving it comes on again. I ordered a new alternator from oreillys and put that on. Still nothing. Im really confused as to what it is so i charged my batteries to get enough to where i could see the codes. Its throwing the p1698, p0252, p0234 codes. I also realized my Oil pressure gauge isnt reading nor is the voltage. Any help is greatly appreciated.Thank you.
