DownByTheRiver
Everything posted by DownByTheRiver
  1. Thanks, I had misread the biasing part and was expecting 5 volts on the CCD+ and CCD- together. So if I don't have voltage at the OBD, I'm going to start unplugging modules along the bus and see if it gets corrected? I did see a change when I unplugged the PCM but was reading voltage across CCD+ and CCD-, instead of each leg to ground.
  2. Yep, ground change reduced ac noise a bunch, Still monkeying with the no bus though. Any advice on the post before the last one about voltage?
  3. AC noise reduced down to .02V at batteries with ground mod done.
  4. Have .254 volts on CCD- and CCD+ at OBD2 plug. Have 12 volts B+ at obd plug. I don't own a DRB3 tool, but should i start unplugging things on the bus until the voltage goes back up to 5v at the OBD2? edit: unplugging the PCM sends the voltage up to .485.
  5. Just read it, and thanks for the diagram. So what's the best way to test this, just start unplugging these connectors, or use a scope? One more thing: I've had the ABS light on for a while, and one time I went to the dealer (to check the ABS code, and the tech said their DRB3 tool couldn't communicate with the module. Unplugging the ABS connector doesn't make the gauges come back or no bus go away though. I lose some gauges right away, but the others are delayed by about 5 seconds. That, to me seems like component failure in the PCM. The manual does say if the resistance of the PCM ground is less than 10 ohms, replace the PCM. Mine tested at 0.1 ohms. I'm doing the W/T ground mod anyway, but it seems like it may be too late. Maybe alternator noise killed the VP44 and the PCM? It was 50 mV when I checked.
  6. 2001 3500, manual A few months ago, 'no bus' showed up on my gauge cluster, and the gauges died. Truck started and ran fine, but no gauges after a few seconds past startup. Was driving it on short trips until it started stumbled and started getting loud fuel knock going down the road at 45. Brought it home, let it sit for a week. Next time I fired it up, it was smoking really good at idle, and cleared up when it was warm, but it's down on power pretty good once warm. Codes pulled at this point are: P0237, P0234, P1698, P0216 I reset the codes and only P0216 and P1698 came back. Gauge codes are 920, 921, 940 ,950, 999 I'm going to do the W/T ground mod and check my other grounds, because I'm wondering how the PCM and VP44 both miraculously crapped out at the same time. Alternator to battery shows ~50mv of ac. Ground test from pass fender ground to 31 of PCM C1 connector shows 0.1 ohms. Have 12v B+ and IGN+ on pcm connector. 0.1 ohms at pin 31 of PCM is bad PCM according to FSM, so I shipped it off to a place last week and they said it was good, but I'm finding that hard to believe given what I've seen. Here's what they said: I guess I'm going to dig into CCD stuff next. Any other ideas? When I first got the truck a few years ago, the gauges weren't working, but I replaced the cluster and didn't have any problems until no bus. I also re-did my dash two years ago and changed the CTM to the high line truck that I got the interior from. My truck is a base model, but had to make the harness match. I figured this was all pertinent information, but I drove for a while before any issues of no bus came up.
