Drew24v
  1. Is their a reason why their is 0 smoke no matter what fueling or custom tune I put my truck on? I know no smoke is best and has crazy power but its just odd no matter what fuel setting or any tune I can't do a little puff puff.
  2. Hello, I recently installed brand new DAP 150HP Performance Injectors. I went from 50HP to 150HP. After installing them the truck started up fine. I let it sit for a bit and wanted to go test drive it and once I put it in Drive the truck acted like it was going to stall out. I drove it and it drove fine however the truck is lopey and if I click the gas slightly and let off quickly the truck will actually stall out. My truck is a 24v Automatic. The Truck Produces 0 Smoke. I hooked up the Quadzilla Adrealine and Still the same Lopey and Stalling Issue but Drives good. It is wire tapped. I put many tunes on the truck and still 0 smoke. I'm thinking its my VP44 that is going out or my Airdog not pushing enough PSI but I don't have a Fuel Pressure Gadge. Exact Injectors I bought : https://www.dieselautopower.com/diesel-auto-power-150hp-aftermarket-performance-injectors-7x0-010-sac-vp7x10sac150a
