cummin-get-it
  1. no loss of oil or fuel in the oil, and it looks just like that video. except this morning it was around 50 degrees out and it seemed alot worse. I am just real paranoid i guess! thank you.
  2. is there anything other than bad piston rings that can effect it? if not im just going to have to compression test it and see if the rings are bad.
  3. i drove my truck for about a half an hour the other day and noticed a good amount of smoke coming from the breather, it hadnt done it this bad all summer. usually a little haze, but it has also droped down from 70 degrees in the morning to around 50. it also doesnt do it until i drive for about 30 minutes, and havent lost any oil in the last 1000 miles (last oil change). truck has 245,xxx on it so they probably need adjusted anyway. any answers would be greatly apreciated.
  4. i put 1 quart of lucas stop leak in it about 2 months ago then i changed my oil about a month ago, i filled it the proper amount and now its up
  5. its not antifreeze, the radiator is clean and the over flow tank is full, could engine oil stop leak be the problem? the oil doesnt smell like fuel. also the oil doesnt turn translusent its black, when i did the paper towel thing.
  6. My oil level keeps going up slowly, i checked for blow by and didn't find anything. the truck still runs great and i am wondering if i could have a small fuel leak from like my injectors or crossover tubes and what could i do to test it. any help would be appreciated.
  7. ok thank you, i will checkout the autoparts store tomorrow.
  8. Where could i get a mechanical guage from?
  9. I was driving my truck to day and my check guages light came on when i came to a stop at a stop sign. My oil psi guage on the dash was jumping around and went to 0 psi then back to its usual spot. I used my quadzilla to check it and it said 8 psi idle with foot on the brake. So my question is it just the guage or sensor or worse? any help would be great.
  10. I have a quad adrenaline but i had a regular comp before and i think it was better. I am really thinking about selling the quad and going back to a comp but drag version. does anyone run a drag comp here?
  11. is there a way i could use the k&n elbow with the bhaf?
  12. quick update i took my intercooler boots off and looked around inside and saw bareley any oil inside of it which makes me think it was just over oiling my filter. I also checked my turbo and it has alittle up and down play but i think after i get my tax refund i might get an hx35/40 hybrid for $175. and i plan on doing the vent tube fix next weekend. thank you for all the help this is deffinetly the best site i have found!!!
  13. still have the stock vent tube, the entire bottom of my truck has oil on it so its kinda what makes me think the fan is blowing oil all over from the vent tube. i am gona take a better look at tomorrow and check my intercooler and see if my turbo has any play.
  14. First off im new to this site but ive found lots of useful info on here which has lead me to creating an acount. ok to begin i just rebuilt my vac pump, but im still getting a leak from that general area. i think its coming from the crankcase vent tube, i also noticed when i had the intercooler pipe off there was oil in there which makes me think my turbo is leaking? but would that make it come out of the vent tube? It only leaks out after driving a while. i checked for blow by today and didnt find any. i also saw that it smokes white out the vent tube. to add some more to it I re-oiled my K&N filter 3k miles ago and i think i might have used alittle much on it could that be whats in my intercooler? any help would be great! Thanks in advance.
