Busadave
Everything posted by Busadave
  1. Looks like I’ve been able to finally find the issue. There is a failure in the OD solenoid/ wiring. Between pins 5 and 6 there should be 28-68 ohms. I have OL. All other resistances are within spec. New solenoid assembly will be here tomorrow. I should have found this earlier when I was doing all my diagnostics but couldn’t see the PIN numbers on the trans side plug with my mirror. Should have used my head and just plugged in the connector and probed the wires. But I got sidetracked with the relay circuit. It didn’t make sense that as soon as the relay was installed the PCM killed the ground whether the trans plug was connected or not. I guess the little current draw from the relay was enough for the pcm to kick to limp mode because it wasn’t reading from the trans. Just didn’t make sense that the circuit had all the hots and ground without the relay plugged in.
  2. I had no codes, but I just have a standard OBD2 scanner. From what I’ve read it may or may not pick those up. I tried to ohm the pins on the trans side of the connector but couldn’t see too well with the mirror. Probably should just plug the connector in and probe the wires. im going to drop the pan when the rain stops and just go ahead and replace the OD/TCC solenoid and harness as I believe I’ve ruled out damm near everything else. thank you for your help.
  3. Grounds are good. I went over the complete pcm/trans harness with it removed from the truck. Do you happen to know if the red wire (pin 1) at the 8pin transmission connector would have the 12v with the connector unplugged at the transmission with the engine on? Or does the PCM need to see the gov pressure, trans temp, etc that also comes through that connector.
  4. Quick question, with the 8pin connector unplugged at the transmission, will the pin 1 (red wire) still have power, or will the pcm shut off the relay because it’s not getting reading from pressure sensors, etc?
  5. Ok understood. My tach is working. So I’m pretty sure my sensor and wiring is good going into the ecm. I haven’t been able to get any readings coming out of the ecm to the pcm on the grey/blk wire.
  6. I see you mentioned abs computer. So I think we’re talking about different things. I am asking about the ESS (engine speed sensor) or what would be the crank sensor anywhere else. That also would be a varied frequency.
  7. Trying to track down the test procedures for the ess (engine speed sensor) on a 99 ram 24v. I’m assuming it would be in hertz? I’m trying to see if my ecm is correctly giving this reading to the pcm.
  8. It’s not that. The pcm is killing the ground for the relay as soon as it’s plugged in. I verified this at the pcm by probing the wire that supplies ground to the relay. It has continuity to ground, then as soon as the relay is plugged in the pcm kills it.
  9. There are no codes with my OBDII scanner I swapped that relay with the horn relay. Horn still worked and trans still did not. speedo works. Tach works haven’t checked the internal temp sensor. I will have to look into that. I did disconnect and clean the connections on the firewall where the harnesses meet. the TC and OD are out of the loop with the trans connector disconnected so that shouldn’t be the cause of no 12v on the red wire pin 1 from the trans relay.
  10. I did see that. I do have the 5v on the orange wire. the other possible issues listed there should out of the loop as it’s doing it without the transmission plug connected. Ive tested all the wires in that circuit for shorts to ground and shorts to hot and not found anything that would cause this.
  11. 5.9 Cummins 47RE No previous issues. Went out one morning, started the truck and trans was in 3rd gear limp mode. No low gear, No OD So I jumped the gun without diagnosing and just went ahead and Replaced the typical governor pressure sensor and transducer, however issue remained the same. Started testing wires and found pin#1 on transmission connector does not have 12v with engine running like it should. Thought problem was PCM. So I sent it out to be rebuilt and they tested it and said it was good and had no issues when testing it. I Re-installed PCM and issue remained the same. I tried a jumper wire in the distribution box where the trans relay goes. With this installed I of course get the 12v to the trans connector pin#1 and have gears 1,2,3 and TC lockup. But no OD as the PCM isn’t commanding it I presume. I found testing the trans relay connector side of the distribution box that the powers and ground are all there to actuate the relay without the relay installed. However as soon as the relay is installed, the PCM kills the ground side of the relay. this happens both when the transmission connector is plugged in at the trans or unplugged at the trans. This leads me to believe it is not an internal trans issue. But the PCM is seeing something it doesn’t like and going into limp mode. I just can’t seem to find what? I haven’t been able to find any obvious wiring defects. Found a couple possible defects but repaired them with no change to the issue. Tried another known good PCM from a friend’s truck and issue remained the same. After doing some more reading today, I’m thinking another possible cause of this could be the ess signal coming from the ecm to the pcm. But not sure how to test this? you fellas have any other ideas?
