mrcodec24
  1. Thanks i assumed, i already emailed them
  2. so i have a 2001 24valve 6 speed and i screwed up on welding some exhaust on the truck, i had the batteries unhooked but i forgot to move my ground when welding a exhaust hanger from the frame back to the exhaust and when i tried to weld the exhaust it searched for the ground through the engine block and so far i found that it took out my CTM and ABS module, when i hooked the battery back up the headlight stayed on and the wipers stayed on also with the abs pump running, i narrowed it down to i uplugged the ctm and the lights and wipers stop, the truck would start for few seconds then die so i unhook the pcm and truck will run and take pedal up to about 2000rpm, with the pcm hooked up i can communicate with the pcm and ecm with my scanner and my cluster works. i have the premium ctm, i ordered a used ctm with the exact part number as the one i have, i plugged it in with the pcm plugged and and i get nothing not even the start and run for a few seconds, it seamed to lock out the ecm even with pcm unplugged unless i unhook battery for a few seconds, im pretty good with a computer and electronics i want to know if i can program this new ctm with my key? or if i can get lucky with moving a chip from my old one? or even better get a pcm possibly with no antitheft?
