sngsht
  1. I took some pics as I did mine last week, and thought I'd try making a write up on it. Basic tools etc. you'll need are , approx. 8qts. of ATF+4/filter,Governor press. solenoid and transducer,1/4' drive torque wrench, 1/4" & 3/8" socket sets, basic metric wrench set, a pick or small screwdriver, a drill with a 1/2" bit for the drain plug kit, big catch pan:thumbup2:, and a paint pen or sharpie,plus whatever I forgot:ashamed: 1) Drop pan to drain the fluid, the easiest way is to go around and loosen them all just a turn, then work from one side loosen the bolts in steps. The idea is to get the pan to drop on only one side to minimize spilling and dump the fluid off a corner- easier said than done. I'd recommend putting a drain plug in the pan while it's off ,to make draining the fluid easier. 2)Pic of the Solenoid and transducer, I used the Borg-Warner 50185 Solenoid upgrade instead of the OEM , recommended because of it's larger magnet, and the difference in my shifts is amazing.. 3)Remove the filter and there they are, your going to need a torx bit-T40 I believe and socket to drop it out, but first you'll need unplug the the electrical connectors to the solenoid and transducer, go easy with them ,the hot cold cycles tend to make them brittle. 4)I removed the two torx screws and bolts, leaving the bolt closest to the rear band adjuster in, this will hold the base on the valve body,no risk of gasket damage doing it this way.At this point you can pull gently on the stamped retainer and the governor solenoid will pop out of the base,since its held in a slot in the retainer. The transducer will remain , just make a note of it's orientation and then pull it out as well. If you notice, there is a slot in the retainer that indexes to a groove in the transducer also, thats to hold it in after reassembly Comparison pic old vs. new. 5) Slide the transducer into the spacer after coating the o-rings with some ATF, make sure that it's turned so that the slot will line up properly with the retainer ,oil the o-rings on the solenoid and slide it into the slot in the retainer.Hold it in the bracket ,and reinstall the opposite of how you removed it,just make sure the retainer is lining up with the slot in the transducer as you guide it in. It should go in easily, if you have to force it stop and verify everything's all lined up, before you go primal on it torque all the fasteners, hook up the connectors and your done! Eezy peezy.. 6) Now's the time to adjust the rear band, it's a easy job but it has to be done right,if you don't do it properly, bad (expensive) things are probably coming your way. That being said, crack loose the lock nut, and back it off 4-5 turns so it doesn't bottom out as you tighten the band. Get yourself a 1/4" torque wrench and 5.5mm socket.Tighten the band to 72 INCH lbs then back off 3 full turns ,hold the adjuster (very important) so it doesn't turn as you tighten the locknut-25ft lbs. Here's a couple of tips, use the paint marker on the adjuster to make a reference mark, AFTER you've reached your final torque.Then carefully take note of it's location and back it off the 3 turns. Then after you tighten the locknut, this mark also gives you a positive verification that it hasn't turned, as you tightened it. It's much better to err on the loose side band adjustments, too tight is probably gonna break some parts. I personally like using a beam type wrench so that I can see it coming up on it's final torque, and I also back off the torque values by 10% since it's a worn in band- right or wrong that's my opinion only. I don't have any pics but,the front band is essentially the same procedure. Its a little difficult to get to and if you have one, a crow foot wrench will come in handy! Back off the lock nut a few turns ,use a torx bit to tighten the adjuster to 72 INCH lbs. then mark it and back it off 1 3/4 turns ( I went 2 turns because of my err a bit on the looser side opinion) then hold firmly as you tighten the lock nut- if you can torque it great! your a better man than I,there's just not enough room in there for my pudgy hands :shrug:a wrench and a torque wrench, just wing it ,it will be fine.. 7) Install the filter 8) Pick a spot on the pan where your sure the drain plug wont interfere with anything, drill a 1/2" hole ( at least in my kit) and install per instructions.This kit had a o-ring for the plug seal, only no groove to retain the o-ring when you tightened it, so I replaced it with a fiber washer.Install the pan, tighten the fasteners in a criss -cross pattern and fill with fluid. 9) I started with 5qts. of fluid ,fired her up and let it idle in neutral , and then added more fluid, while checking for leaks, as needed to bring the level up to full. Your done! Take her for a drive and recheck for leaks , and fluid level.. -
  2. This is a fairly simple, straightforward job, needing only basic hand tools.I took some pics as I replaced mine last week, and thought I'd try making a write up on it. Basic tools etc. you'll need are , approx. 8qts. of ATF+4/ trans. filter,Governor press. solenoid and transducer. You'll need 1/4" drive torque wrench,sockets,basic 3/8" socket set,a pick or small screwdriver, a drill with a 1/2" bit for the drain plug kit that's going to be installed,a big catch pan, and a paint pen or sharpie,plus whatever I forgot 1) Drop pan to drain the fluid, the easiest way is to go around and loosen them all just a turn, then work from one side loosen the bolts in steps. The idea is to get the pan to drop on only one side, this will minimize spilling and dump the fluid off a corner- easier said than done. I'd recommend putting a drain plug in the pan while it's off ,to make draining the fluid easier. 2)Here's a Pic of the Solenoid and transducer, I used the Borg-Warner 50185 Solenoid upgrade instead of the OEM , recommended because of it's larger magnet, and the difference in my shifts is amazing.. 3)Remove the filter and there they are, your going to need a torx bit-T40 I believe and socket to drop it out, but first you'll need unplug the the electrical connectors to the solenoid and transducer, go easy with them ,the hot cold cycles tend to make them brittle. 4)I removed the two torx screws and bolts, leaving the bolt closest to the rear band adjuster in, this will hold the base on the valve body,no risk of gasket damage doing it this way.At this point you can pull gently on the stamped retainer and the governor solenoid will pop out of the base,since its held in a slot in the retainer. The transducer will remain ,make a note of it's orientation and it will pull out as well. If you notice there is a slot in the retainer that indexes to a groove in the transducer also to hold it in after reassembly. Comparison pic of the old vs. new. 5) Slide the transducer into the spacer after coating the o-rings with some ATF, make sure that it's turned so that the slot will line up properly with the retainer ,oil the o-rings on the solenoid and slide it into the slot in the retainer.Hold it in the bracket ,and reinstall the opposite of how you removed it,just make sure the retainer is lining up with the slot in the transducer as you guide it in. It should go in easily, if you have to force it stop and verify everything's all lined up, before you go primal on it! torque all the fasteners, hook up the connectors and your done! Eezy peezy. 6) Now's the time to adjust the rear band, it's a easy job but it has to be done right,if you don't do it properly, bad (expensive) things are probably coming your way. That being said, crack loose the lock nut, and back it off 4-5 turns so it doesn't bottom out as you tighten the band. Get yourself a 1/4" torque wrench and 5.5mm socket.Tighten the band to 72 INCH lbs then back off 3 full turns ,hold the adjuster (very important) so it doesn't turn as you tighten the locknut-25ft lbs. Here's a couple of tips, use the paint marker on the adjuster to make a reference mark, AFTER you've reached your final torque.Then carefully take note of it's location and back it off the 3 turns. After you've tightened the locknut, this mark also gives you a positive verification that it hasn't turned, while you tightened it. It's much better to err on the loose side with band adjustments, too tight and it's probably gonna break some parts. I personally like using a beam type wrench on these,so that I can see it coming up on it's final torque, and I also back off the torque values by 10% since it's a worn in band- right or wrong that's my opinion only. I don't have any pics but,the front band is essentially the same procedure. Its a little difficult to get to and if you have one, a crow foot wrench will come in handy! Back off the lock nut a few turns ,use a torx bit to tighten the adjuster to 72 INCH lbs. then mark it and back it off 1 3/4 turns ( I went 2 turns because of my err a bit on the looser side opinion) then hold firmly as you tighten the lock nut- if you can torque it great! your a better man than I,there's just not enough room in there for my pudgy hands a wrench and a torque wrench, just wing it ,it will be fine.. 7) Install the filter. 8) Pick a spot on the pan where your sure the drain plug wont interfere with anything, drill a 1/2" hole ( at least in my kit) and install per instructions.This kit had a o-ring for the plug seal, only no groove to retain the o-ring when you tightened it, so I replaced it with a fiber washer. Install the pan, and tighten the fasteners using a criss -cross pattern then fill with fluid. 9) I started with 5qts. of fluid ,fired her up and let it idle in neutral , and then added more fluid, while checking for leaks, as needed to bring the level up to full. Your done! Take her for a drive and enjoy the crisp shifts,as always go back and recheck for leaks , and confirm proper fluid level..
  3. I have one on the way Thanks for the tip !
  4. Well the "fix" didn't last long - 15-20 starts and it quit working again. 43 degrees ambient temp this morning and no light, the heaters definitely cycle after it starts, but I guess I can't say 100% that they are working when I turn the key forward initially. The voltmeter pulls way down when I turn the key and it starts pretty much instantly so I'm guessing that they must be cycling with the key- just no indicator. I guess I'll have to look into the ultra gauge AH-64.. Hoping I don't have a ECM issue, I read a couple threads in another forum suggesting that this is a early indicator that the ECM is failing . I'm not sure that pertains necessarily to the '06's though since these were 2nd gen threads I believe..
  5. Hahahaha feels like it ! Northern Michigan..When I first moved up here, I was completely off grid for about 6 weeks, everyone said there's no way your truck is gonna start in the mornings. This Cummins lit right up every morning, in temps as low as 23 below... Blew the power stroke guys at work away. Lol
  6. Temps are more than cool enough, it's been in the 40's at night here, high of 55 today lol.. Its always came on briefly with the light check when you turn the key on ,hopefully it was just a glitch and disconnecting the battery fixed it.
  7. Yesterday afternoon I disconnected the batteries for 30 minutes and loosened/tightened the ground lead to the ECM and when I started it this afternoon it came on as usual. Hopefully that took care of it , I'll pull the ground lead off and clean it for good measure.
  8. I should add that I got those codes by holding the tripmeter in and turning on the key..I haven't been able to get any codes by doing the " on-off-on-off-on " method?
  9. That's what I had hoped, but it lit up when I did the key/tripmeter self test for fault codes. Doesn't light up at any other time..
  10. Upper 40's in the AM, 60-70 daytime temps. it doesn't come on even when I initially turn the key forward. In the past,It always came on with the other lights for a few seconds during the indicator lamp check , regardless of the temp ..
  11. Hey guy's , my "wait to start " indicator quit working a couple days ago. No apparent performance issues, the grid heaters are still cycling like normal ( I can see the voltage pull down a few times when I first light it up). No other apparent engine related symptoms, starts and runs just like she should. The only issues I have with it is one of the rear power door locks ceased to function, and occasionally the shift indicator doesnt fully recognize it's in park and sounds the horn when I open the door I just tap the shifter up towards park and that takes care of it so I'm assuming it just needs adjusted. Anyone have any ideas of where to start looking? i did the self test on it and came up with these codes: , 282 S 121 C 447 HR 2988 I'm having a little trouble matching them up with anything relevant to this truck or problem? Any help you might have sure would be appreciated!!
  12. Just wanted to give you a update, it was the flat 4 trailer connector. I had already taken the 7 pin apart and checked it (unfortunately it was -3 out, so locks on the connector snapped the minute I breathed on them ) since that's the only one I use, but it was clean so coated it with dialectric grease and put it back together. Pulled the flat 4 down out of the bumper ,pulled the cap off and was greeted with a sea of green corrosion- you could see where two pins had bridged together..Cleaned it up and greased it and alls well! Thanks for the help, that was a cheap fix!!
  13. Thanks for the info guy's, I've been pulling a trailer quite a bit so the plug has definitely been open and exposed to quite a bit of salt/sand this year- I'll look there first and work my way forward
  14. Thanks- thats what I was thinking - Thought I was posting in the Non - powertrain forum but I must have fat fingered my phone and slid it in here instead
  15. Hi guy's, greeting from snowy Michigan! This has been my first winter with the Jr. Cummins up here and I've been very impressed! No problems at all starting in temps as low as 18 below (Not plugged in) she's impressed the other diesel owners at work aswell , they pretty much don't drive theirs in the winter,and when they do, they all plug them in . Anyway back on topic- when I rolled into the cottage tonight and flipped off the lights , I noticed that when I had my foot on the brake , my right front turn signal was glowing dimly, let off brake light goes out. So I did a walk around and checked all the lights and everything but a front side marker was working. Right turn signals worked correctly, BUT when I checked the left turn signals (with the headlights off) the right signal and brake light flashed along with it. When the headlights are on , everything seems to work properly.. There haven't been any harness or wire mods that I know of, but the truck has been working in some downright nasty conditions for the last 2-3 months and this seems to scream bad ground, or a fault somewhere to me. Any problem areas I should look into first or is this something that might be a switch or board issue with the multi functin turn signal switch? Sorry for the long post and thanks for any info you can share!
