4x4 Nut
Quarterly Subscription
Everything posted by 4x4 Nut
  1. Hello, I have a 2002 Dodge 2500, 5.9L 24V Cummins that’s been down for months & so far is stumping me. It has Auto trans, 4WD, & about 190k miles. As far as I know it’s all stock except for a FASS DDRP fuel pump. This is a long one, but any help or suggestions would be greatly appreciated! Truck was running fine & then died. Cranks (spins good), but no start. First thing noticed was fuel pump not running. Then also saw gauges are not working, no wait to start light, & odometer flashes a few times then displays “NO BUS”. It will connect but not communicate with a scan tool. It either displays no communication from module or circuit open (from the airbag module). The OBDII scanner adapter lights up & I have Ign + & ground at the connector. That of course lead me on a CCD communication path for troubleshooting. I started by disconnecting each module or component, 1 at a time, in the CCD circuit. Got it down to only ECM, PCM, & cluster connected- no change. Went ahead & removed the cluster & still no start. While removing I inspected each connector for damaged terminals, corrosion, or dirt. They all looked good. I then checked the CCD wiring- for short to each other (the Bus + & Bus - pairs), short to ground on each wire, & short to Ign + on each. No shorts or incorrect continuity found on any of that. I also continuity tested each CCD terminal to all the other connector terminals for each wire. Every terminal has continuity with all others on each of the wire pairs. I then started checking all the grounds, battery +, & Ign + wires to the ECM, PCM & OBD II connectors, Every one of those tested well (even load testing them). I have also checked all fuses (good). At some point in there I self-tested the cluster. Every light & gauges seems to function properly. At the end I get 920, 921, & 999 errors in the odometer display. Seems to point to PCM problem… I have checked battery grounds to body & other points. All OK. I haven’t dug into doing a W-T ground wire mod, but doesn’t SEEM to be an issue with that either. Maybe I’m wrong though?… There is a ground wire to the block just above the starter & according to wiring diagrams, it grounds the fuel pump, fuel heater, A/C compressor clutch, & the CAN-BUS ground. The wire terminal seems good & 3 of the 4 connectors have good continuity to ground. I haven’t found the Cummins Can-Bus connector to check that. Diagrams show it’s located on front left of engine & has 3 terminals ( Bus +, Bus -, & ground). I’m unsure of where or how to check that…. I pulled the PCM & sent it off for bench test & repair. It was returned saying nothing wrong with it. Next I sent out the ECM. They found some corroded terminals & repaired solder connections. I was hopeful that their findings were the issue, but no change after reinstalling so doesn’t seem to be either of those. Next I went digging deeper in the CCD system. I’ve gone through some flow charts that don’t seem to show any issues. I’ve read multiple threads on here about CCD & saw posted that you need 2.49- 2.51v on each of the CCD wires to ground. I have 2.45v on each of them. I have a troubleshooting flowchart from Mitchell ProDemand that says I need 1.8v to 2.3v. So I guess I’m in range, but can’t say 100% either. Swapped PCM with a good running 2001 Cummins 2500, AT, 4WD. Both trucks functioned the same way as before even with a different PCM. This truck still had flashing odometer & NO BUS with the ’01 PCM. The other truck ran fine on the ’02 PCM. So that tells me the PCM in this truck is probably fine. The only thing that I can think of is to either swap the cluster (but I don’t really think that will do anything) or go back through all my wiring & fuses again in case I missed something. Or I am very open to suggestions if you have thoughts on this? Thanks for any help. I greatly appreciate it.
