corychoate
Everything posted by corychoate
  1. Hey Moparman, Thanks for the help, but this morning I broke down and called edge to order the adapter after trying to figure it out all of sunday. 30 bucks all in all so not too bad! Yea I was trying to figure out the pin placement to see if I could replicate it, but the 02 is massively different than the 01 map. Thanks again, Cory
  2. Hey guys, I bought a comp, and the previous user had it set up for his 01 with the 01 connectors on it. I guess this is the early version of the comp box because the new ones come with adapters for the 02 that use the 01 connectors, while the early ones did not. The 02 connectors were loose in the box. I cut the 01 connectors off and now need to attach the 02 connectors, but I'm having a problem. On top is the 01 connector, and on bottom is the 02 connector. As you can see, the 01 connector has 3 wires going to it from the lead, a green white and black (Or brown?) and the 02 connector only has 2 bare leads going to it. Anyone have any idea how the 02 connector is supposed to be hooked up? Thanks much, Cory
