The_Master
  1. Hi All,Just checking to see if there were any major wiring changes between the 1996 and 1997 years. I have a 1996 Ram 2500 Cummins and just had a major wiring issue.Apparently the interior dome light wires shorted and melted all the way down to underneath the dash. I had a good bit of smoke and was testing w/20A fuse and for some reason the fuse failed to blow (defective)? I had to manually pull it and then I pulled the batteries because I was not sure that the smoke had stopped.Today I have to go through those massive wiring bundles and figure out what damage has been done.The pink wire running up to the ceiling is the melted wire.Anyone with any helpful comments would be appreciated.Thanks,Nathan
