9453
  1. NO TEMP RISE SEEN FROM INTAKE HEATERS Ok got that part now what I did was eliminate the heater (Ca. warm wheather) to get a little more flow, I left the solenoids hooked up and insulated the heater ends in hope of fooling the computer no luck so wondering what you guys do to keep from thrown this code
  2. Yes it is leaking a little bit at the right front cornner. I found a head off of a 98 with low miles approx 26000 was thinking that it might be in pretty good shape as the engine it was on lost a cylinder.
  3. I'm looking to get another head for my 01 HO just so I can have it already to go when I change my head gasket don't want any issues when I get into it now I found a head with low miles sounds like a pretty good deal the only thing is that it's from a 98 24v now will this work on my HO??? Thanks
  4. Right on guys that helps thank you 10 minutes added to an oil change no biggie.
  5. I have an H/O 6 speed exhaust brake 2001 3500 with 15300 miles now I was stumbling around here and found a thread on cleaning these sensors so I went ahead and pulled them out and and they where very black to say the least now I pulled a pretty good hill just to see where I was at on the EGT and boost then claened the sensors and the same numbers came up didn't seem to help right off the gitgo now should I notice a difference long term or should I be looking at somthing else. Truck seems to run fine no problems but you know could always use more power.Also I do have a banks performance chip don't remember witch one maybe this is over ridding these sensors any ideas?
