HELLO
Everything posted by HELLO
  1. thanks..... - - - Updated - - - Thank for the link.... good info
  2. can some one tell me if the turbocharger is ok to have side to side play on the blades. it dose not have end play. the blades do not seem to be hitting the housing the truck has 160,000 miles on it thanks Joe
  3. Thanks for your help was int sure if some one goofed up. i picked up a 56 block i am going thought it. new gaskets. front and rear main seals tap it cover. new water pump cleaning injectors. timing cover case is up dated so no kdp. new cam sensor.going to rebuild the old motor out of the truck after i install this one
  4. ok i am cleaning my fuel injectors and in one of them there are 2 shims. i do not know if some one has put them in by mistake. the fist one i cleaned has one shim the 2nd one has 2 can some one tell if that is wright thanks
