airborne66
Everything posted by airborne66
  1. when I go back with the bolts don't I need to put something on the threads of the bolts that hold down the horn and the throttle bracket also the injector lines and if so what is best ??? thx - - - Updated - - - how do I turn up my lp its in tank and id love to know its pushing 13-15 at filter and banjo bolt at inj pump
  2. how much does the lift pump need to push my sons is pushing 13-15 while its pumping on both sides of the filter and at the injection pump
  3. can anyone tyell me where the part number for the 00 cummins injector pump is located Thanks.
  4. so your saying I need a new injector pump or my son does ? what does that usually run
  5. hey guys I hope you can help, I... am in the wounded warrior currently at home recovering also my son is active marine at 19 in va. this weekend he was able to come home for a 96'r and right after he filled up his trk and went to tell my parents bye, his truk cut off it hits with a little shot of either, we bleed the filter it had a little air,and checked the pressure before the filter and at the injector pump at both it was right at 15 lbs the truck barely runs but not every time. I checked the codes with a borrowed reader it had codes 0251 fuel quantity solenoid open or short circuit, ecm has detected a open or excessive current on the fuel circuit solenoid...code 0253 fuel quantity solenoid short to ground ecm detected a short to ground condition on the fuel quantity solenoid circuit...0252 fuel quantity solenoid circuit malfuncition..ecm has detected an excessive current condition on the fuel quantity solenoid...1688 fuel injector pump controller failure condition .. ecm has detected an internal failure of the fuel injector pump module .. so if you guys could please help im not able to do much but my dad , ( who is also a 3 year VET of Vietnam ) we think we can fix it we both cme from a pretty mechanical back ground , old school thanks so much oh almost forgot 2000 dodge ram 5.9 cummins 5 speed
