j.barrett
  1. j.barrett changed their profile photo
  2. Hello everyone. I am either not very good at searching or this topic hasn't been talked about yet. Here it is. Friday night i get home from work. Go to roll up my drivers window. It goes up half as then stops. I tried it again.. No luck. I tried every Window from the driver door. Then i tried every Window on each door at the door itself. Nothing. Then i tried the mirrors. Nothing. I then checked the power locks and they worked fine. So then i grabbed a test light and checked every fuse and all of them are good. So i then bought a new master window switch. And. Nothing. Still dead but power locks work. Has anyone else experienced this? If so how was it fixed?
  3. hi everyone thanks for taking some time to read this.. I was driving home today on the freeway thinking how nice my truck was running. I got into town left the shop light and the truck stayed in first gear. I let off the throttle and it shifted into second. It held second gear until I let off again. I have a converter lockup switch and the shift relay pulled and jumped. It's been this way for years. Now this happened... Another note I have 2 old optima batteries that are having a hard time starting the truck when it's cold in the morning. I'm open to hear theories ideas ect. Thanks again
  4. Thank you ABennin abd mopar1973man both great ideas. This week be the route taken
  5. Hi everyone, I am trying to get all the gauges l on my edge programmer to work, I'm lacking on the fuel pressure , I had it hooked up working fine, then I installed a fass fuel pump the big one, and doing that eliminated the banjo fitting at the vp44 , so my question is could someone please tell me where I can find a fitting like a T that will let me screw the sensor into the side. ? Or any suggestions?
  6. I tow with over drive off.. . It's just on some of the road s I'm towing on are extremely steep grades and only one lane per direction..
  7. I'm trying to help out an old friend, he is wondering if there is a way to adjust idle speed. Any help is appreciated.
  8. I appreciate all the feed back. Thanks everyone
  9. It's a tow rig mainly. I drive it about once a week.. with the 3:54 gears it's awesome on the freeway, but towing up step grades is not to good.. I wouldn't mind down sizing tires but I'm running recentered h1 wheels that are 16.5
  10. Hello everyone, I'm trying to to figure out what gear ratio would be best in my truck. It's a 2000 , 2500 ,automatic. Stock gears in it are 3:54 and I put 37 inch military tires on it.. I am planning on gearing it but I need advice and opinions on what ratio to have installed.... 4:10 ? Or 4:56? , if I do 4:10 I can use stock carriers, if I go 4:56 I have to buy new carriers. what is the best for towing or all around.
  11. It's time for new tires on my 2000 , i was wondering how many people have the h1's With military 37s on their dodge s, if so how much lift was needed, ive heard a leveling kit and they fit, but want to make sure before i spend the money.
  12. I replaced the pcm with a new one from dodge, and had it programmed for my mileage and vin because the original one was smoked so Arter i got that done it's time to start fixing the other things like the overdrive situation.
  13. alright, I sold my 2002 dodge 2500 last week and picked up a 2000 Laramie slt 2500 short bed, its real nice! I like it. I had to have a new PCM installed in it today. (thankfully I have a great hook up ) so now the gauges work. but here is my dilemma , the guy I bought it from has 2 switches mounted on the lower dash, one is for converter lock up, the other is for over drive. and the transmission relay in the fuse block under the hood has been removed and 2 prongs are looped, (it does have a check engine light from it..) so I removed the looped wire, installed a new relay and leave the switches off. with the over drive button on it wont go into over drive. I check the wires at the plug on the trans, and 2 of the wires have been vampire tapped to those switches on the dash. I would really like to get this figured out and eliminate those switches. any ideas?
  14. Can't figure this out, please, help. My truck turns on and runs.. But non of my gauges are working on the dash. The odometer window says no bus. Any one have this happen?
  15. cool, thanks, I will see what can be done. I do know I am going to run a fuel pressure gauge.
