Seanjj
  1. I installed the DS1413 MOOG track bar . I did the ball stud end first . Then I had help from my 6 year old who turned the steering wheel for me while I lined up the bolt hole on the axle bracket. The MOOG packaging said a higher torque ball stud but listed no torque.. I called MOOG and the guy there said it meant more durable not a higher torque on the nut . So 70 ft/lbs on ball stud and 130 ft/lbs on axle bracket bolt. Now to track down where the rest of the play is at....
  2. I think I will just use the Moog problem solver trackbar - DS1413. It cheap and has the lifetime warranty. I’m going to go through the front end afterwards to. I’m getting sick of the wondering . Thanks for all the help and replies. Is an alignment required after replacing the track bar?
  3. The OEM one did last 308000 kms and 16 years... well steering did get sloppy a few years back but that’s not bad on OEM design I guess.
  4. I like to do my own work to to save money and learn more and to know it’s done right. Have you heard of Spohn track bars? SKU # D94-02-TB-DS. . They have one for the truck but I haven’t heard of it before.
  5. My track bar just separated at the balljoint near the differential. Which is the best upgrade and why? I read on a few sites that the newer dodge pickups will match up front end components.? I also can turn the steering wheel about 3” to 4” before I get response for steering. What should I do to correct this steering and get it back to new steering. I have 285/75R 16 tires and stock 16” wheels. No other mods accept for a Darin’s steering stabilizer. The truck is a 2002 HO Cummins 2500 Sport
  6. So I took it to the dealer this morning because I wanted them to check and make sure they never set something off. They told me it was my relays and it happens a lot ... I checked for codes as soon as I got back in the truck. Now it says PCU 0500,1694, 1693 and ECU 0382, 1693. Why wouldn't that show up before I gave it to them?
  7. The P0234 is probably cause by a heavy foot and the smaller boost elbow. P0500 I heard is from spinning the tires and not really moving, not sure if that's totally true. But with the torque of these truck on icy streets it happens a lot .
  8. One morning I had the check engine light stay on but it was gone when I fired it up again.
  9. These codes showed up in the order as follows. PCU 0500,1694,1693. ECU 0234,1693.
  10. It seems since I brought my truck into the dealer for the 3 cylinder high idle cold start enabling my grid heaters haven't worked. I see the wait to start light come on but the voltage doesn't change. I have to plug it in even at 0'C now or it won't start. Lots of white smoke for the first few minutes when I do get it running . Could there be another problem I'm missing maybe? Can a dealer possible program stuff to mess up or maybe accidentally delete my grid heaters somehow?
  11. It used to start easier at -20*C before when not plugged in.
  12. I noticed now whenever I don't plug the truck in when it's at 0*C or just below it will barely start . And when it did go once it sounded like it was in 3 cylinder while running for the first 10-15 seconds. Anyone else notice this after having the high idle cold start enabled?
  13. I'm pretty sure the 3 cylinder mode is working to. Sounds horrible though .
  14. Makes me wonder what they did the first time I brought the truck there.
