rudyroo11
  1. rudyroo11 changed their profile photo
  2. Good looking, I'll hit him and go from there.
  3. they're two wire, Ill start splice'n tomorrow! Thanks again, you've been a great help.
  4. I am installing some candle sticks, which are fancy marker lights for the outside of the truck. I want to splice into the marker lights/turn signal so they turn on when the parking lights are on and blink with the turn signal. the marker lights have 3 wires: Green, Black, and I think its purple with a white line. Which ones would I splice into to get my candle sticks to work the way I am looking for? Thanks for the time and help.
  5. I have a 47re automatic transmission and about 1-2months ago lost over drive, so at 55mph Im riding at 3k rpms. I have to take back roads every where lol. I have a beater for now to get around over 40mph. I am wanting to swap my automatic for a stick. I live in Strongsville, Ohio which is between Cleveland and Akron on the westside. Any one know a place within 3-4 hours where they would have everything I need? Thanks in advance for the help, and Happy New Year!
  6. well at last I have power and boost gage is pretty I had replace just about everything and found out is was a 40 and 50 amp fuse blown. Thank you for the help and have a safe new year!!!
  7. Thanks a lot fellas. I will dive into the fuses hopefully this week if not over the weekend. Ill keep you posted. Thanks again, you guys are always helpful.
  8. Ok, Ill have to pick that up. Thank you. Since I cut into the wire should I re connect it? it only punched in the wire barely.
  9. I did check the fuses and they don't look blown. Its a 2000. Any idea what fuse could be bad that wouldn't let the truck get any power? Or any relay maybe?
  10. Yesterday I installed a boost gage on my truck. One wire needed to be connected to a 12v ignition power wire. I spliced the wire into the red wire coming down from the ignition. When I did this sparks ignited. I disconnected the splice but now when I try and start the truck there is no power. Nothing. Any ideas out there? Thanks for the time fellas.
  11. Ok good deal. I have a 2000 slt 4wd.
  12. What a great help, much appreciated man! Thank you. I have a Haynes manual, is there better ones out there specifically for the diesel?
  13. Is that spring hard to replace? Sorry for all the questions, but im green on this tranny thing.
  14. The ATS link just dropped me into their home page. No article.
  15. Thank you very much. This will be a great help and start. I looked in my Haynes manual and it didn't have anything on the O/D switch, where is it located or is there a better manual out there were I can look up these specs?
