Elkaholic
Everything posted by Elkaholic
  1. Has anyone put one of the Fass electric heater kits in an Airdog FP-100? It looks like it will screw in next to the supply line from the tank above the water separator. With my Airdog exposed under the truck, even with anti-gel additive, it will gel up driving down the road. It was -17 this morning and I made it about 1.5 miles to the store fine. I left it running and ran in for 3-4 minutes and when I got back in it started loping real bad and I noticed the fuel pressure was Zero. I shut it down, then limped it around to the back of the building out of the way so I could deal with it after it warmed up some. I finally got the fuel flowing about 2:00 PM and got it home. The Fass electric heater can be run to a toggle switch inside the cab and turned on manually when needed. The heating element senses the temperature and will shut it off when necessary also. I'm hoping I can mount it in the hole next to the supply line from the tank and not affect the operation of the Airdog in any way. The other option I was looking at was the WVO small filter heater wrap. It's much less money, but it pulls a lot of amps. Please tell me the Fass heater will work....
  2. Likeoldfords and Dripley, Yes, I agree, DAP is a good bet and I believe in supporting the businesses that sponsor the forum. Luke, I know what you mean about other things taking priority, it took me 13 years to get the Edge JWA in my truck so I can now monitor the things I need to. I still need to add the TST Products J-hook kit to my turbo waste gate actuator because mine has the solid tube where the boost elbow should go, and I also want to get a High Idle Kit from DAP too. It's only a couple hundred bucks of stuff, but with two kids and all it will take me a few months to get them. When you say the "fuel relay" went out, do you mean the relay for the pump that is mounted to the firewall on the truck and supplies the 12 V power to the Air Dog? If that is the one you mean it should just be a standard relay available at any auto parts store for cheap. Nothing special about them. It's lucky you have the option of going back to the stock in-the-tank pump, when mine died the truck was down for a week waiting on Air Dog to ship out the new tower assembly. Elkaholic
  3. I am installing a new Edge Juice with Attitude in my 2001 Dodge Ram 2500. The kit comes with a new Boost Elbow, but my turbo has the hard line between the tubo and the waste gate actuator. All it said in the manual is that on some trucks you can't install the elbow. What affect will this have? I read something in a thread about installing a turnbuckle on the WGA, but when I searched for more information, noting came up. I am assuming that you are installing it on the rod from the WGA to the WG and using the turnbuckle to adjust the psi the WG opens at. Is this worth doing? The truck is basically stock, BHAF and 4" exh but no other HP mods. Thanks for any help you can provide.
  4. Luke, I learned about the washers under the Return To Tank fitting here on the forum, Mopar1973Man had mentioned it. Basically there is a ball-check under the return to tank fitting, and if you make it harder for the ball to move and open the line, your pump will send more pressure to the injection pump. My FP-100 indicates that it is pre-set at 15 psi, but it never did any better than 13.5 psi or so. I put two 1/4" washers between the fitting and the spring and my pressure going to my injection pump is now 17-18 psi. I used a 3/8 drill to open up the innerr diameter of the washers, then took them to my belt sander and reduced the outer diameter so they fit in the port. The screen is the first thing the fuel goes through when it enters the Air Dog, it is in the nipple that the water separator screws on to. You can remove the water separator and unscrew the nipple with a deep-well socket or crescent wrench. It is held in the nipple with a star washer that is compressed into the edges of the nipple. I pulled the star washer out with a jewelers screwdriver and put it back in by hitting a socket with a hammer. Unless it is really loaded up with stuff, I recommend just blowing it out with air if there's anything in there. Mine had quite a bit of fiber debris around the edge so I took it all the way out. As far as not having a gauge, you can find enough horror stories on the web about lift pumps and Air Dogs failing to keep you reading for a year. If you are running a VP-44 fuel injection pump in a pre-2003 Dodge Ram you really should be monitoring your fuel pressure to the injection pump. Dodge says anything under 5 psi can kill the FI pump, but I start to worry if it goes below 8 psi. You can get a gauge, or they have a warning light kit at Geno's Garage you can install that will go off at 5 psi. For the money you spend on the gauge, it's still way cheaper than what it costs to replace your fuel injection pump. If it's just the injection pump, the cheapest I've found is $990 plus the core. If you have to add the lift pump or Air Dog too you're looking at another $350 to $590, and that is if you do the work yourself. I got lucky, my Air Dog is under their Lifetime Warranty so they shipped out a new pump/motor tower assembly for nothing and I found a used VP-44 for $500. I installed them myself. The downside is that I didn't purchase a reman'd pump, so there's no warranty on it. If you want to put a gauge in and have the time to comparrison shop online, try Geno's Garage out of Georgia, Alligator Performance out of Idaho, and Kens Performance out of California. I've purchased things from all of them and I can personally attest to the excellent customer service you will get from Geno's and Ken's. I should also say that you could support one of the Sponsors of this forum and buy from them also, I just haven't used any of them myself. Elkaholic
  5. I'm not worried about the pump being harmed by debris. My concern is that the screen on the inlet fitting to the water separator becomes loaded up with this fiber type stuff and starves the pump for flow. This in turn starves out my injection pump and then I'm out a grand because I didn't add a $5 inline filter to catch the crap until it works it's way out of the system.
  6. Hello all, I just installed a new Gearotor/Motor tower assembly on my Air Dog FP-100. While it was out on the bench, I noticed there was some debris in the pre-filter screen at the inlet to the water separator. It looks like disintegrated paper, I think my wife had the small cardboard seal in the cap of a bottle of fuel treatment fall into the tank months back. Now it has broken down and the fibers are clogging the screen. I have 1/2" fuel lines for the whole system, can anyone recommend a good in-line filter to cut into the pump supply line? I would like one that I can disassemble to replace the element and clean. Most of the in-line filters I have seen are for 1/4" to 3/8" lines, can I get one for 1/2" lines that won't cause a detrimental amount of flow restriction to the Air Dog? The last thing I need is to fail another pump on it, I'm already on my 4th pump in 7 years. Thanks in advance for any recommendations/suggestions. J Turner
  7. So, here's the update on this. I installed two washers under the spring in the return to tank fitting and also put in a new sending unit for the Auto Meter gauge on the dash so I can now actually see what my pressure is. With the old pump it would make 16-17 psi at idle, and drop to as low as 10-11 psi under throttle. I received the new gearotor/motor tower assembly today and installed it. While I had the pump out on the bench, I noticed the pre-filter screen at the inlet to the water separator had some debris clogging the screen. I cleaned it thoroughly and installed the new tower assembly. It now makes 17-18 psi at idle, and stays above 15 psi under throttle. I'm satisfied that it is working correctly, and to verify my pressures, I also received my package from Geno's Garage with a new Test Gauge. There is a 2-3 psi difference between the in-cab Auto meter and the Test Gauge, but they are both within the range I am looking to maintain, above 14.5 psi under throttle to keep flow past the computer on the VP-44. Thank you to the members here that helped me out with advice and recommendations, especially Mopar1973Man.
  8. Thanks Michael, I'm hoping my new sending unit gets here for my FP gauge on the steering column. I'm not sure how much I trust my old test gauge. I bought a new test gauge too , but I bought it from Geno's Garage and when I spoke to them yesterday the lady said the Atlanta area has come to a halt because of the weather. She said it looked like UPS was shut down. Hopefully it will get shipped today and I'll have it by Saturday. I'm going to fabricate another washer so it's ready when I get the new Air Dog pump installed.
  9. Ahh yes, now I remember why I quit spending time on forums, a half dozen replies and not a single answer to the original question of "should it take more than one washer to shim the spring under the return to tank fitting to raise the pump output pressure noticeably?" Not sure a new FASS system is in the budget right now, but a possibility. First thing is to get the new gearotor/motor assembly in my hands and bolted in place. What I see for output flow and pressure will be a major determining factor on buying a FASS right away.
  10. If you have the Lifetime Warranty on the pump, why did Air Dog charge you for the replacement? I've had four pumps fail, and I've not paid them anything for the replacements.
  11. Hello all, I'm new to this forum and have already found a wealth of information. I have an Air Dog FP-100 on my '01 Dodge Ram 2500 QC with the standard power Cummins. It has just failed the Air Dog pump for the 3rd time, this time costing me a new fuel injection pump. The gearotor/motor assembly was just installed in Sept. I put in the new fuel injection pump and everything tested fine. I knew the Air Dog was not putting out as much pressure as I would like, so before I ran the truck further than a couple miles, I installed a 1/4" washer that I drilled out to 3/8" ID and then shaved the OD to fit under the return to tank fitting in the Air Dog base. I drove the truck about 35 miles and then I installed a new 10 micron fuel filter. On the return trip home the truck started acting like it was starving for fuel and the injection pump was dying again. I managed to limp it home. I put my test gauge on the fuel line (the sending unit for the gauge on my dash is dead) and at idle I'm getting just under 8 psi, as I throttle up the gauge drops to zero. I called Air Dog, and once again, they are sending me a new gearotor/motor assembly. I also purchased a new sending unit for the FP gauge on my steering column, and a new test gauge for verifying. They should be here about the same time the new Air Dog pump gets here. I would like to know if you have to put more than one washer under the spring in the return to tank fitting to increase the pressure above 14.5 psi? I only installed the single washer, should I add another one? My average reading at idle with a pump that's not jacked up is 13 psi, but I'll have to get the new pump installed and re-verify everything again. The original Air Dog was installed in '07 and failed in Feb. '11. That one failed in Sept. '13 and the first gearotor/motor assembly they sent me didn't pump at all. They sent me a second unit and I verified it was working with a bucket flow test. I even changed out all my fuel lines when I installed this second pump, thinking I might have a blockage but found none. This is the one that has failed now, after only 4 months. Needless to say, Air Dog is not my favorite company right now. I'm very close to just installing a FASS and once I get the new pump put on, sell the FP-100 to recover some of the cost of the new unit. Any ideas on why I'm failing so many Air Dogs? Should one washer be enough? TIA, Elkaholic
