68AMXAMC
Everything posted by 68AMXAMC
  1. Shame no one rebuilds the VP-44 computer. I was a computer tech for 15 years," old school" I'm sure it is only a half cooked transistor, that can't take the heat in the kitchen.
  2. Thanks for all of the advice everybody! Here is an update, received the new pump from Air Dog, installed it brought the pressure up to 16lb at idle. Replaced the fuel pump relay. All codes were cleared and have not returned. But the truck still stalls, and still is hard to start when hot, @ average operating temp 190 degrees. But when I run cool or cold water over the VP-44 it will start and run fine , until it gets hot again. Still no codes. I am pretty sure the low fuel pressure issue with the lift pump has done its damage to the VP-44 . Any other ideas would be great, hate to buy another VP-44 this one is only 2 1/2 years old, less than 50K miles on it. Thanks Sam Y
  3. I just tried your test for the code 1689. As per the video ,removed the relay and cranked the starter. Yes it set the 1689 code again, but unlike your video my pressure gauge read 0 pressure during the cranking. Is this because I am using an Air Dog pump ?? Or am I missing something about the test. Still waiting for UPS to deliver the new replacement for my Air Dog, hopefully Monday.
  4. Hi Mopartechnican, I forgot to mention that I have done that several times. I have used a garden hose and ran cool water over the VP44 , and it does make things better until the temp comes back up. But the temp range seems to be getting lower all the time. It was stalling at 160 degrees and yesterday it as stalling at 140. And as you know driving and having the engine shut off is un-nerving . I cleared the codes today but have not test drove it to see if they come back, yet.
  5. Hi everybody, my first question on Mopar1973Man. I have a stock 2001 Dodge 24v . In Jan.2012 had a lift pump failure & cooked VP44. Replaced with rebuilt VP44,and a Air Dog 150. About a month ago started to have a problem with hot starts, would start and stall. I only had the idiot light for the fuel pressure warning, never came on. Problem continued to get worse. Bought a real fuel pressure gauge and discovered I had 13lbs. at idle and would drop below 10 lbs. any thing above idle, replaced filters, both were only a month old, no change. So I put the 17lb spring into the Air Dog that came with the pump. Now I get 15lb at idle , and the pressure drops to 13lb anything over idle. WOT will cause a drop below10lb. Called Air Dog and they are sending a new pump, still waiting for the UPS to deliver. I have codes P0122 and 1689. I am doing the tests listed by Mopar73man for these codes tomorrow. Truck runs strong when cold, even at these fuel pressures, but as soon as it reaches 160 degrees the stalling and hard starts return. Removed thermostat helped some, but I live in central Florida, and everything is hot here I think the VP-44 is on its way to death. Any suggestions ? Thanks Sam Y
