Charlie_plott
  1. I have a nv4500 that is making a noise in 4th gear when slowing down between 1000-1300 rpms it was rebuilt 2k miles ago it has a southbend clutch its not a grinding or clunk sound more like a bearing ? Could it also be the harmonics in that gear when slowing down ? My damper wobbles a little need help !!!
  2. Ok I go to tap my vp44 and the wire you are supposed to tap is missing the insulation and some of the wires are broke ? Can you replace the wire ?
  3. I changed the oil 3k miles I check weekly I haven't had to add any and I did a u joint and ball joints myself last week but it runs strong no blow by at all I do need a rubber gasket that goes on the shifter tower it leaks and a rear axel seal ! Does the rear axel pull out like the front ?
  4. Is there anything I should be worried about with this many miles
