jflord
Everything posted by jflord
  1. didn't look at that, as far as trading ecm my other truck is going into camp so no time for that, but thanks John
  2. Thanks, oh boy just what I wanted to do this week, spend lots of cash on a not so sure thing.
  3. No ac reading at all but the alt gets hot after 10 min. Any thoughts on where to get a ecu without getting a second mortgage? Thanks for all the help so far. John
  4. Hi all, new to this forum and do I have a good one. what we have here is a 2001 3500 drw 6 speed, chip is back to stock 4 inch exh and a k&n, other than that all stock. Ok here we go, I have a pile of codes and I don't always get the same ones when I clear them. 1693 0522 0117 1475 0237 0217 1295 0122 0127 these are the most common ones I get back when I ether clear them with disconnecting the batts or with a scanner or the smarty. The other thing is going on is the gages are all over the map, temp goes up to 240 and sets more chimes and things, oil gage intermittent, volt sometimes goes down when revving up and oh, the thing misses horribly. So these are the things I have tried, load tested batts, cleaned terminals, checked all the grounds under hood, pulled all terminals apart and inspected, checked for the ac bled, alt puts out 14 v and connections are good, started to get water in fuel light but I have an airdog and do not have that function but drained and checked anyway, checked all fuses, said a lot of bad hatefull things. Well with my 2 index fingers sore I hope someone out there can help. Thanks John
