Marc_4x4
  1. Ok where can i see it sory in a loser with the internet :p
  2. Ok where can i see it sory in a loser with the internet :p
  3. I got my 01 truck swap buy the other custumer and he put a 98.5 in it that cause the truck runing in limp mode because off the différence in the tone ring 98.5 to 00 run cam and crank and 01 to 02 just have cam sensor. Now my truck is a 01 with auto transmission can i put a 01 manuel block with all my stuff on its like vp44 and the turbo
  4. I want to know if the vp44 is the same for a 1998.5 to a 2001 or there is difference between?
  5. Okey so the edge ez is chipper but have the same torque? For now i want to have a litle more power and when a destroye my tranny gone a have more power
  6. Which one is the best for a good mpg and not to much for destroying my auto transmission
  7. Yes confirm that its a 01 and its someone that doing mecanic of cummins for 20 years but for the warrenty i am not sure have to talk with the person
  8. Okey because i check and a after market cam is like 700$ and a 01 block i have found one to 1250$
  9. No i did not get the donor truck. Ok i gonna check for a cam and gear housing . But you think its cheaper to change the cam to replace the engine and sell mine that its in the truck
  10. But if i change the cam i need timming cover and the 01 cam but is this a big jobs or its easy to change the cam because i dont want the truck to have probleme after changing this
  11. Oh ok its less trouble to get a 01 block and putt my vp44 on it
  12. Only a cam gear from a 01 and the cover and my truck will run fine? Because i heard people talking that this those not work amd that the hole cam *** to be swap
  13. Ok because the truck is a 01 that have been swap with a 98.5 and the truck is in limp mode because off the diffenrence cam 01 and cam and crank sensor 98.5 . So i want to buy a 01 block with no turbo manifold and vp44 so i want to put all my stoff that run the 98.5 on the 01 that deserve to be in the truck
  14. I want to know If the vp44 gear is the same in 98.5 to 01 , and also if all the gear in the 98.5 timming cover is the same that 01 have
  15. So if i understand i cant keep the pcm off my 01 truck butt i have to reflash it and on the ecm with the wiring have to be change tthans for the advise
