Marc_4x4
Everything posted by Marc_4x4
  1. Ok where can i see it sory in a loser with the internet :p
  2. Ok where can i see it sory in a loser with the internet :p
  3. I got my 01 truck swap buy the other custumer and he put a 98.5 in it that cause the truck runing in limp mode because off the différence in the tone ring 98.5 to 00 run cam and crank and 01 to 02 just have cam sensor. Now my truck is a 01 with auto transmission can i put a 01 manuel block with all my stuff on its like vp44 and the turbo
  4. I want to know if the vp44 is the same for a 1998.5 to a 2001 or there is difference between?
  5. Okey so the edge ez is chipper but have the same torque? For now i want to have a litle more power and when a destroye my tranny gone a have more power
  6. Which one is the best for a good mpg and not to much for destroying my auto transmission
  7. Yes confirm that its a 01 and its someone that doing mecanic of cummins for 20 years but for the warrenty i am not sure have to talk with the person
  8. Okey because i check and a after market cam is like 700$ and a 01 block i have found one to 1250$
  9. No i did not get the donor truck. Ok i gonna check for a cam and gear housing . But you think its cheaper to change the cam to replace the engine and sell mine that its in the truck
  10. But if i change the cam i need timming cover and the 01 cam but is this a big jobs or its easy to change the cam because i dont want the truck to have probleme after changing this
  11. Oh ok its less trouble to get a 01 block and putt my vp44 on it
  12. Only a cam gear from a 01 and the cover and my truck will run fine? Because i heard people talking that this those not work amd that the hole cam *** to be swap
  13. Ok because the truck is a 01 that have been swap with a 98.5 and the truck is in limp mode because off the diffenrence cam 01 and cam and crank sensor 98.5 . So i want to buy a 01 block with no turbo manifold and vp44 so i want to put all my stoff that run the 98.5 on the 01 that deserve to be in the truck
  14. I want to know If the vp44 gear is the same in 98.5 to 01 , and also if all the gear in the 98.5 timming cover is the same that 01 have
  15. So if i understand i cant keep the pcm off my 01 truck butt i have to reflash it and on the ecm with the wiring have to be change tthans for the advise
  16. So the best thing to do is swaping all the wiring and computer under the hood
  17. Ok but just the cam gear or all the cam in the block aand with gear case i've to change the vp44 gear to?
  18. Its the reading on the gear i can not post picture butt i have one that show the diffenrence
  19. Yes a heard to so the best is like to swap all computer and wiring or the hood years motor
  20. I read so many thing about that i got a p0341 and i think my trouble is the cam gear that read a differente things dose anyone have alraidy done this and cam i juste change the cam gear and the cover or i have to change the hole cam? Or its more simple to take the 98.5 wiring and swap it in my 01 please help me im pist off that i bought a truck like this
  21. But if the ecm and pcm alraidy programed in 01
  22. Ok but can i make the 98.5 engine run like a 01? Without changing all my wiring emc, pcm because only the reading on the cam is changing the block still all the same?
  23. Yes start like a new truck run good all gauge are ok temps and charging are all ok the truck run really fine butt its in (limp mode) so i have no power
  24. So i cheque the web you place amd its sais that its all compatible 98.5 to 02
  25. Motor is 03/25/1998 and truck ecm 03/13/00
