Chad3304
  1. It does actually, spoke with the previola owner he stated it was a smone switch.
  2. It's showing TCC Solenoid is off at all times. Going to replace the solenoid and see if that fixes it.
  3. Yes, it is a new to me truck. It seems to get worse once it's warmed up. I did notice, that once it's stalled and I put it into N and re start it, if I put it down to 1 real fast rather than Drive it will go ahead and take off.
  4. Hello, I have a 01 cummins auto, only mods are 75Hp injectors, and a fass. I just had a new injection pump installed, however the problem was there before this. When the truck is put into gear from P or N, it stalls. It will fire right back up, and when you get it to stay running, it acts as if it's under a load. When put back into park from Drive or reverse if it stays running, the RPM's jump up as if I tapped the throttle. Anyone know what this could be? Thanks in advance!
