tom377
  1. thank you mopar1973man. Temp gauge works no swings or jumps. no revving. Do you or any one know where or who knows how to troubleshoot a haunted ecm or pcm. bluechip said you might could help. Thanks
  2. 98.5 3500 4x4 auto stock 113,00mi Dealer recall at 12k mi to reprogram for nox emmisions ( recall no 8001 ) cut fuel mi to 5 loaded 12 empty and easy. after 2 reflash dodge said thats normal. To shorten a very long story with the great help of Bluechip diesel and the jumper wire trick they and i don't think its the vp44. Followed there detailed and very helpful diagnostic section plus some others. Problems started with oil press gauge showing 60 with out engine running. Changed it, same thing. Next intermittent dead pedal, rest apps no change. next, intermittent dead tach- dead petal- ck eng light- abs light and brake light. Several codes, cleared computer with apps reset procedure more than once. Among other codes 0336 and 0222 came up every time. Changed crank sensor and apps, no change. Problems grew into VERY little power until op temp above 140. After up to temp still have all other issues, dead pedal-christmas lights on in the dash- dead tach and oil press 60 running or not. Started checking codes every time driven to learn pattern of my gremlin. Problems grew to cold start -die- wait 2 min. start - die each time it will run a little longer, after 5 -10 cycles it will run. NO power until warm. During start-die cycles i must wait about. 2 min each time with key OFF. If the key is left on it will not reset. If i don't wait long enough, no start, no fuel pump and no wait to start light. Cold mornings won't start at all if not plugged in. when in start die mode using Bluechips jumper trick it will start and stay running for hours even cold. newest symptom when warm, a couple of hard starts and one no start. Cycled the key a few times to get wait to start light, then started. Code list , In order over 1 month but only being driven 5-6 times. X denotes multiples of same code. 1693 every time (companion code) 0336and 0222 Every time (even if you don't start , when i erase codes ck eng. light just flashes off then back on with these codes) 1594 x2 0216 x3 1689 x4 Checked every plug i can find. Checked harness every where it can be seen touched or wiggled. Removed ecm to ck for corrosion, plug condition etc. Installed ground wires on vp44, ecm and ecu on the fire wall. Local shops and dealers are no help. ( dealer said change every thing including lift pump and harness. AND would not give quote) I have tried all the normal things, Cant afford to throw money at it. Please help. Thank you
