cguyfish
  1. I most prob gonna throw it all away
  2. I got the sender float arm off. Also the small bracket that held arm and circuit on.Also unplugged wire harness . But dont know how to unplug the two wires from the plug itself
  3. I got the arm off and see how the circuit board comes off but the other part appears to slide up into slot. Not worried about screen. Mopar1973man is right. No need if I've allready got a spinon. Plus the inline on suction of pump. Plus canister up front. Gonna get out my maginfier glass to see it. ha
  4. How do you take the sender off of the moduel?
  5. thing seems to be wrong on site. "My Settings" does not have a " Sig" button
  6. Thanks... I think I will leave it off. And just change sender/float. I've allready got an inline screwon just before Raptor
  7. my Settings does not have a Signature button. neither Profile Customization
  8. I cant seem to find userCP. Signature page. I looked under my settings
  9. Guess I need to buy a complete unit. Sender/float is bad and also I tore filter trying to remove it. Wheres a good source for a complete unit. or should I just change out those 2 parts
  10. Where is the shop manual download for 01 5.9? I've got to look up what all those abbreviations are
  11. Ok. I cleared and started it up. Let idle 800 rpm. ran for about 20min fine. I watched scanner temp gauge.... when it got to 153 it cut out once very quickly.5 more min cut out again 156 and again.when it got to 162 it started to miss rapidly almost died and came back.another min and it died....Got the same codes again.stored 1690/pending 1690 / mil / on /freeze frame 1690
  12. I'm affraid to leave house...Quit on road with no help........Can I just clear and crank up later and let run... Mayb throttle at different rpms in neutral?
  13. Thats all ....I recon....Do I need to erase them and try again....?
  14. having problems pairing....most prob me.
