spoonm08
  1. 4bt - in a landcruiser. I've talked to steed a few times on this project, but I dont think he ever got around to testing the 341 actuator. His hybrid method is expensive unless your lucky to find a used newer 341 and there still expensive. My 341 is older off of the f-650 and wont work as a hybrid, but it is 12 volts. Im going to buy a cheap adjustable PWM and see if I can get it to function.
  2. I agree, however the he351ve is to large for my application. The he341ve is better but the few I can find/have only accept a PWM signal as far as I know. Im thinking about integrating the PWM sheild with your project (which is great by the way!) unless someone has a better idea.
  3. Has anyone tried controlling a PWM controlled actuator like on the He341ve using this setup? Maybe incorporating the PWM sheild and changing/adding some code?
