daltana
  1. Thanks. Thought it would need more than 3 wires. What is an enhancement module? A tuner.
  2. While installing my Fass DDRP I found a 3 wire weatherpack connector with a 3 wire weatherpack sealed cap on it. What is it for? I figured it is for a manual truck, NNS and reverse lights. My truck is an automatic.
  3. Could be the ECM. Previous owner installed an on/off switch to control the alternator because the PCM was over charging it. Who knows how much damage was done before I got the truck. The light was missing and I replaced it and functioned normally for awhile. Installed an internally regulated alternator and charges fine now. AC measures. 07 volts at the alternator with all accessories on.
  4. No voltage drop, 14.6. Runs fine. Just had my buddy install a used vp44 due to a p0216 code.
