Alberta Bound
Everything posted by Alberta Bound
  1. I had it checked after the new pump was in and had 22psi. I'm going to get a fuel pressure gauge installed soon. What does a factory pump put out?
  2. Thanks for all the input guys. It turned out to be a bad injection pump. I'm up and running again.
  3. I changed the lift pump a year and a half ago and i can here it running when i bump the starter. The truck didn't do anything funny before it died, just died
  4. I'm not sure what my fuel pressure is (no guage) but i do have fuel to the injectors. I know this by cracking an injector and cranking it over and saw fuel there. As far as what is done to the truck-just 4" aero turbine exhaust and edge comp chip, pillar gauges tranny temp,egt & boost
  5. My truck died on the hiway today(2000 ram 2500 diesel, auto). I did the key trick and the code P1693 showed up along with the code P1682. I believe P1682 has to do with a voltage problem. Where do I start with this? Maybe an external voltage regulator is needed? Am I on the right track and why would the truck just shut off and still have enough juice to turn over at a normal rate? Any help or thoughts on this would be much appreciated.
