Raddemc
Everything posted by Raddemc
  1. It looks great! Prob is I don't need 2! If I do have another prob I'm buying a new one. Thanks for the help!
  2. Well that's what it was. What a wimpy little wire. Solder in a new one. Works perfect now thank you!
  3. Ok thanks we will try and solder the wire back into the loom. Thanks!
  4. Ok I think we found the wire. So does that bare wire attach to the post that's empty?
  5. It'd the post between the yellow coated wire and the black coated wire. The post is there with solder on it but nothing on it.
  6. How can I post pics on here? I can show you where there is solder on one of the posts but no wire. It's like one of the little jumper wires broke off.
  7. The codes it throws are 0113,0118,1693. It will rev up to high idle but not 3cyl mode.
  8. All the shrink wrap is on mine. If I can figure out how to post pics I would show you.
  9. The check engine light turns on when it's flipped. That's why I wanna see the wiring.
  10. Can anyone send a pic of the wiring on the back of a gauge pod high idle switch? Thanks.
