smokedout
Everything posted by smokedout
  1. 2001 dodge cummins 4x4 auto trans . do i have 4 wheel abs?
  2. Yeah i'm repowering a Frieghtliner roll back tow truck with a little older engine i had. Sorry i should of mentioned that in the beginning. Thanks for your help. If i cant find any other info on the allison i'll just use the specs you gave me. I think it will work.
  3. oh thats all right. What i'm doing is putting an allison from a 2nd gen engine on a 1st gen engine. Do you think the torque specs for the dodge adapter and torque converter will work?
  4. Thanks a bunch. I looked all over trying to find it and had no luck. I figured i could get some help here. This is an awesome forum.
  5. WOW! That was fast, thanks man. Any idea on the flexplate?
  6. Does anyone know how many ft/lbs to torque the bolts to on the engine adapter flexplate and torque converter? Thanks:thumbup2:
  7. ill try a manual gauge. in the video what is the switch that the dude is flipping? when he flips the switch that is about where my oil pressure is when the engine is warm, even higher when cold... thanks a bunch guys.
  8. i bought a 98 3500 a few months back and engine oil pressure runs about 70 psi at start up and drops to about 60 psi or a little more when warm. is this normal? i know good oil pressure is good but is this too much? thanks
