gccuda
  1. OK . From that is my understanding on a 2001 . My 1999 has lowline on the st model . Does anyone know that this is the same issue on a highline ctm for a 99 ? Did the highline do the same ? if so how would this affect the ecm and ptm on the 99? I know that the 2001 have a chipped key . Not sure about the 99 . I was of the understanding that all the ecm and ptm in 98.5 and 99 were plug and play . Trying to find a fix ! Thanks for the input . please keep it coming
  2. Ok LOOKING for some help here . I have a 1999 2500 4X4 5 speed Quad St . Recently I did a cab swap over the winter . While putting the truck together I used the 1998.5 Dash and harness from an SLT . While working on the truck it ran great started up after sitting for a couple of months . While were putting it all back together we came across an issue with the 1998.5 dash . the Headlight switch in a 1998.5 and the 1999 are different and we had no headlights . so we switched everything over and put the 1999 dash back into to the truck . So all the harness is 1999 . We went to start the truck and it started and died ! We thought the pump but after all that what was going on we hotwired the pump and it starts? Next we thought the ecm went for a pouch . We had the p1698 code and even after wiping it clean it still a no start . So I purchased a ecm and ptm from a donor truck . Put in the ecm with the original ptm still in . no start! next we put the donor ptm in and it started and stalled about 4 times. now we have a no start again . I found out after that the donor truck has a highline ctm and mine is a low line. So in 1999 I am of the understanding that it is all plug and play . LOOKING FOR SOME input . Just so everyone knows I have changed the Cam and crank sensors trying to get it to start .
