Clarkwisely
Everything posted by Clarkwisely
  1. Maybe I'll try a diffrent computer with Windows 7 or Linux also in your librarys in shows new liquidcrystal is that the same
  2. I Uninstalledon't every thing deleted all the downloadsensors and started over got the libraries from your Google Drive you had and same as version 1.11 I saved it and opened it hit the check and the same thing happened
  3. Mine looks just like that ill Uninstall every thing and try agin
  4. Maybe I'll Uninstaller every thing and try agin what version of the arduino program are you using There should be 4 libraries that I need correct
  5. i have the libarys all downloaded and uploaded now but still i get a long air message is the something i need to do to the code so it will compile and i can upload it.
  6. That my be my problem is may of missed one , thanks That my be my problem is may of missed one , thanks
  7. Ok I planed on using a relay, also I uploaded the 1.11 code to the arduino program and hit verify and had the same error with #include <can.h> Error compiling for board arduino/genuine uno
  8. What about the main turbo plug one is a power is it 12v and another is ground where's the other two connect
  9. Wow thanks abunch that helps a lot the only other question that I have is what pins go to the turbo? With that I hope the code all works out and I get it all running this weekend
  10. Ok I will try that when I get home this afternoon, also how do you wire in the 9924 chip and were.
  11. Yes I am using a uno and I used you latest code that you had posted I downloaded it and also copy and pasted it. Both had the same error . I have a uno and u used the most recent code you had posted I downloaded it and also copied it and pasted did this for the boost and the speed codes.
  12. I purchased all the parts that you had listed to build the setup, and the all arrived this evening, i have couple questions about the 9924 chip were do you wireally it in at hand were do they all go, also what wires from the board will go to the turbo plug and also the speed sensor. Also I decided I would try to run the code on my arduino before I started test assembly but when I downloaded it, and opened it when I tried to verify it it had a error. Any help will greatly be appreciated
