Steamershot
Everything posted by Steamershot
  1. Both injection pumps are SO, i changed the front cover , and cam gear , sensor , harness, all sensors out with the 02 stuff. It seems that the pcm is having a issue not reading the crank sensor , I'm trying to get the guy to mail me the pcm from the 02 now to see if that will straighten it up. Has anybody flashed one of these pcm's from 99 -02 ? And has anybody done what I'm trying to do before with good results?
  2. Here's some images of it , check those numbers out and see if it will work for you. If so I'll take 700 + shipping we can use pay pal. That's what I have in it. Would that be the chik- fil-a on victory Blvd across from kiln creek @dripley ? thats under 5 miles from my Vape shop Home Town Vapor i have a lot more 24v parts available from a thrown rod 02 motor that I tore apart. Let me know what is needed , fair prices
  3. Hello and thank you in advance for any help in this matter. I have a 99 2500 Ram 4wd At SLT Laramie 24v my vp44 died so I bought a complete 02 motor with a thrown rod. I put put on my 99 motor the vp44, complete harness and sensors all of them from new motor , ecm , and the fuel filter can ( newer ones nicer) pulled the cam gear off 99 and installed the 02 cam gear with the grid ring , I left the crank sensor in the hole in block ( no plug for it on new harness of course ) im still using my 99 pcm ,my tach works everything actually seems to working fine. Except the motor is running like a dog and has a idle surge from 800-1200 rpm iratically runs and drives like it's in limp mode hooked the modis up reading as a 02 truck ,and I get a 1690 code injection pump ckp and ecm ckp disagree The intake grid heater is deleted is why the other 2 codes 50034960375__8CC2E6F1-3C0E-412E-A6BD-C098E7DB684B.MOV
  4. I have one in va from 99
  5. Hello all, im new to posting on here , trying to get it right. Id like to start by thanking you for the site , it has been a great tool in repairing my 99 24v im actually having some issues at the moment that I truly need some help with. I have a 1690 code ecm disagrees with pcm after changing my ecm ....... before I go into great detail , just wanna make sure I'm posting in the right spot
