krs
Everything posted by krs
  1. Highly recommend doing a ccv breather delete. That blow by is normal for a diesel but routing it into the intake of the engine is not!! This oil will shorten the life and efficiency of the turbo and reduce efficiency of the intercooler too!. Not to mention the CCV filters are a waste of money to change every 30k-40k miles. I have 3 6.7L cummins and have done it to all of them. There is kits you can buy for cheap to delete this but it is easy and cheap to insert a plug and hose clamp on hose that is upstream of the turbo (between intake filter and turbo). Open up the CCV filter and cut all the garbage out of it. Re-install it and then run a 5/8" hose to approximately the axle like the 5.9L and most pre-emissions vehicles did. Letting the crank case breath on its own is best for the longevity of the engine. GDP makes kits that I did run on all three trucks but the vent/filter that it came with is not as good as a design as I first thought. Not to knock GDP, I really like their other products. What I found was the blow by builds up in that little filter and eventually drips engine oil all over the exhaust manifold and makes a nasty mess. Cheaper and easier to run a piece of heater hose to low point of the engine bay. Feel free to message me if you would like pics, etc..
  2. I have a 2014 Ram 3500 CCLB Dually that has a horrible shudder that I get only in reverse when im backing up a trailer or in soft/muddy conditions. I replaced the crappy two piece drive shaft with a custom 1-piece aluminum to get rid of the Chinese steady bearing. (you have to replace the complete drive shaft for $1600 on this truck from Dodge to change a $130 steady bearing). The shudder is not as bad as it was. I also changed all of the shocks with Fox 2.0 which again improved the situation but not fully. The truck has 76000km or 47224miles. It has 3500lbs in the box at all times the cheap dodge springs have sagged in 2 years and now it rides the overloads. (my 2007 doesn't, cheaper steel in the springs over the span of 7 years; sad) I will be getting two leafs added to each side this week but im not expecting this to fix the problem. I have also not been able to find anything about transmission issues for this particular one. I did a fluid/filter service at 25000kms and again at 73000kms and the fluid still looked new. Any input would be appreciated. The truck is fully deleted and running the way it should've from day one. RaceMe Ultra on the lowest HP setting (30hp).
