Dcarter96
Everything posted by Dcarter96
  1. Ok thank you for the advice. Here are my 3 data logs from the weekend at the track. When spooling up to launch the truck i cannot get the truck to go past 20 psi without the truck dropping back down to 15 psi or jumping to 35 psi. When i was using my edge comp box i could spool to 25 psi to launch at the light. any ideas? Also i turned off the back down settings. I'm just trying to perfect this tune for the 1/8 runs. my first time was 7.93 second was 7.59 and last 8.12 but the last pull i blew the head gasket in the rear. 1st pull no nitrous.csv3rd pull nitrous blew gasket.csv2nd pull 70 jet nitrous.csv dripley, Im running the fass big lines and no i deleted that and also using a sump.
  2. Ok I’m currently running a fass 150. I’m guessing a 220 would be good?
  3. The problem starts at lines 38-46 iQuad-2020-06-02-11.47.25.csv
  4. Here’s the export and it was when I shifted into second gear I hit the lock up switch. iQuad-2020-06-02-12.49.57.numbers
  5. Fass 150, 7x0.014 SAC injectors, .93 tubes, 188-220 Hamilton cam, DAP 103 springs, Hamilton titanium retainers, DAP 7/16 .120 push rods, crazy Carl tunnel ram, DAP intake, Crazy Carl twin piping, S475, S362 SX-E, DAP 3 piece exhaust manifold, sump kit, Muldoon full billet trans triple disc converter, crazy Carl rapper cover, butterflied pistons, full bottom end rebuild, ARP head studs, induction solutions Nitrous kit (not installed yet). DAPGris Hester delete. Bosch VP44 hot rod pump. Quadzilla 4K tuning v2. I think that’s everything lol. 1998.5 2500 I’ll grab a data log for ya today and send it out. I’m guessing just export it to here?
  6. I tried posting this in the 4K tunes spot but it wouldn’t let me choose that. I went to the track this weekend and used the hang on tune from the website. I’m really confused now cause when the truck shifted into second gear I pressed my lock up switch for the torque converter and the truck dies down and then pulls hard but it takes it a second to pull. Also at the light I was spooling up and I could not get the truck to go over 20psi without it trying to cut power back. Any help would be greatly appreciated. Just trying to prove that Quadzilla is the way to go.
  7. So I’ve done some testing with tune and so far it’s great. I’ll get some data logging for ya but was wondering if you had anymore input on anything I should change? I’ll be heading to the track in September and will post some numbers. Thanks in advance. iQuad-2018-08-26-04.08.08.json
