Bremtech
Everything posted by Bremtech
  1. To follow up. With a temporay fuel pressure gage set up I was able to get started. Watching the gage ,things were looking good, about 15-20 psi but then droppped to 0 psi . The fass unit sounded a different tone. Lost prime to the tank. I decided to start from the beginnig at the fuel pick up in the the tank.Time to remove the bed. Long story short, the suction metal line coming out of the tank had a small pin hole hidden under the rust. I fabricated a a new fitting/lines and reinstalled. Have not tried start yet. I am installing a set of gages,fuel pressure,boost and egt. I will let you know how I make out over next few days. Enjoy your labor day.
  2. Fuel Injector Pump term. 6 :3.0ohms to Engine block ground location, 5.7 to (-) battery.
  3. Thanks for the diagrams, I do have the manual and I am getting a little better at reading them each day. The problem is in the grounds/system of grounds. I charged the batteries and now reading 12.4 v at termial 7. When I test the ground,meter set on audio ringer, I get a low/scratchy wisper -vs- a shout. When I repaired the ground down by the starter I discovered that the actual copper wire was oxidized ,black in color not shiny as a new penny. I would say the ground wires have Taken a beating over the last 12 years. Looks like running new wires is in my future.I will be studying those grounding diagrams.Thanks for your feedback and focus.
  4. I am only getting 9.4 volts to termimal 7 with the key on. The key was the one that came with the pump and was installed correctly,removed nut and washer to double check key to gear position and is correct.Not sure of the best way to check ground other than the ringer on ohms on the meter. I would say i need the full 12 volts.
  5. The vp44 is new / rebuilt thru Diesel Auto Power. My thoughts is the the fuel is not going thru the pump.My next step is to put the old pump back on and see what happens.
  6. Hello,My 1998.5 24v would not start after a short trip to UPS. Had the truck towed to my shop. Sat for a few days until I could get a new fuel filter and water seperator for the FASS fuel pump, installed and primed,fired right up. Died after a 15 mile trip home.Sat for a few hours until I could get a 3/4 wrench to prime again. Got it started and drove 3 miles to my home. I had a hot rod injector pump that I really did not like so I figured it was time to replace. Changed pump,fresh injectors, no start.Read codes. Found bad connector for the mapps/boost sensor,repaired, new mapps sensor also installed along with a crank sensor. Also found a bad ground to the block located between the emc and the starter. Two different grounds one terminal. Ihave 20psi of fuel pressure. Having trouble bleeding the lines, some just do not want to bleed . Will not start. After clearing codes. No new codes . Any thoughts
