espanton
  1. hello, my nv4500 hd transmission broke.cant afford to buy one.i do have a standard duty transmission from a 2001 2500 v8 lying around.my question is can i swap the front input shaft from the hd tranny to the standard duty tranny without any modication or changing anything else?thanks!
  2. Hello. I changed the pinion bearing on my 1999 dodge 2500 cummins. and i put back the shims that has been there. and if i tighten the pinion nut it will not turn. My question is if all the shims was put back in place and i over tightened the pinion nut should the pinion still turn? or i have to have it torqued right? I dont have a 500 torque wrench. or should i buy a shim (between the yoke and outer bearing?. I need to fix my diff in2 days the garage will be used after that. thanks in advance for any help. espanton@telusplanet.net
