Notch86
Everything posted by Notch86
  1. Ordered it from auto module source
  2. Yeah pretty much you gotta do what you gotta do the bigger hit to the wallet was the new quad adrenaline I just bought but that was more of a want than a a need
  3. I know it's been awhile but I figured I'd give a update I replaced the ecm and all is good
  4. So I went through the diagnostics I'm no longer getting the p1689 code on the p0122 and p0341 they both seem to point to the ecm being bad
  5. Thanks guys I'll try to start looking into ithe after work tomorrow but it may be this weekend before I really have much time I'll keep you updated
  6. I'll start going through the diagnostics tomorrow after I get off work I see several references. To using a DRBIII scan tool which all I have is a basic code reader will that be a problem
  7. Hello all I'm Stephen I'm from Bowling Green KY I've got a 2001 Cummins 4x4 6-speed
  8. I have a 2001 Cummins 4x4 6-speed the truck starts and idles fine but I'm getting several codes and have dead pedal and the rpm on the tach drops to zero at idle The codes are P0122 P0238 P0341 P1689 What I've done so far is Replaced apps with a timbo Replaced map sensor Replaced cam sensor Cleaned every ground I can find I'm really now sure where to look from here Thanks for any help in advance
