Cowboyup72490
  1. Copy will do if I can find the laptop lol.
  2. I have a old laptop I could use. Why would I need to build a tune on the computer when I can do it straight from the app. I just switched to iOS I got tired of the slow android tablet I used. I didn’t have a problem with the android just can’t do it with the iPhone.
  3. Can someone post up the values of the daily stock injector with meat 1.9 tune l. I bought it and can’t get it to download to the app on iOS. I tried emailing it to myself and everything and can’t get it. I’m pretty good with a phone and can’t get it. I looked through old threads and can’t find it. Only find outdated ones that’s been updated since posted. You can post up other tunes as well. Thank you.
  4. I forgot to add my truck used to be a manual but I swapped it to a auto. No the trans is not stock it's fully built other than a billet output shaft. Has a DPC triple disc converter, and yes the low boost setting on the edge are turned all the way up.
  5. I'm having some issues with my 02. Lately I've had no low boost fueling. It's a 02 built auto with a edge comp and 50hp injectors. The fuel pressure is good and the only codes I'm getting are 0622 and 1765. You can feel the edge changing power levels, and there is little to no smoke at wot or wot from a stop. Also about a month ago everytime I drop it in gear it will stall unless I let it warm up for 10+ minutes. Any help would be much appreciate. Thank you.
