WARDEN
Everything posted by WARDEN
  1. BIG thanks to all.it was the front prop shaft.i would have thought it could have been re-built, but nobody had parts.$280.00 , 1yr warrantyMERRY CHRISTMAS everybody
  2. 99 3/4 ton diesel 4x4,241hdwhen in 4wd i have loud clunking under front of truck.iv'e checked in the diff and both axle u-joints and front bearings.all look good, could it be the front drive shaft u-joints making this noise?any body had trouble with this?thanks in advance
  3. IT'S A99 2500 ,no blown fuse. no problem at all except wait to start light stopped coming on.
  4. THANKS , I'LL check fuse. it has always flashed on in warmer weather and the truck still starts and runs perfectly , it just quit coming on at all so i was wandering where to start.
  5. hey all , been a while.ya'll got me going last time i had trouble , maybe someone has had this problem. my wait to start light quit coming on. could it be my grid heater?
  6. That was it, running like a spotted ape again.Thanks,great site
  7. thats what i think too. i'm not sure if the 99 has a cam sen. i got my fingers crossed , going to put it in tonite, i'll let you know.. thanks
  8. thanks again. i also forgot to mention that when the chk eng lite came on the tach would go to zero..
  9. thanks , i picked up a scan tool this morning , but i can't get the truck to start at all. it never missed or stumbled , i drove it home and went to move it and it has not even tried to start.i'm hoping the crank sensor works. iv'e checked connections and grounds and plugs, all seem ok
  10. new to site and diesels. i have a 99 2500 4x4 , ctd with an edge ez. the truck has never died but will not start. lift pump shows 14 lb at hwy speed. chk engine lite came on but goes off every time i re-start it.auto zone check shows no codes. from other fourms it appears i could have a bad crank shaft pos. sensor. i have bleed the fuel lines and get plenty of flow but i do not know at what pressure. any help or suggestions would be appreciatted. thanks in advance
