Rod
  1. hey Llamajwc what are you using for a power supply? sounds like it might be a low current issue maybe
  2. I know in the holset etool it reads out the data (historical time at what temperature, lifetime, time spent above max temp... only if I had a Etool to log..................
  3. Does anyone know what the commands are to read the historical data from HE300 such as temperature, lifetime etc? Thanks!
  4. thanks jibayes that's what I had I'll log it and post the canbus logs and the actual requested//reported as indicated by the scan tool thanks
  5. I'll dig into it a bit more have you tried these commands on a new style actuator and do they work? might end up logging the lines going to the turbo thanks
  6. yes I did the pinout is for the 2014 according to alldata 1-Ground 2-data low 3-data high 4-12v
  7. the actuator moves and the truck can control it but I cant with the arduino the older one I can set positions no problem thanks
  8. I built the arduino setup that I picked up the pieces of the code on here.. have built it and it worked on my friends 2010 no problem ( thanks BTW!) it won't talk to my 2014 actuator (new style where the connector is on the he351 housing) i realize the wiring on the connectors are different and have it wired correctly thanks!
  9. hey guys can anyone help me with getting this test /calibration code working on my 2014 6.7 thanks in advance!
